Asystent parkowania... próbował ktoś w OIIFL?
  • misiek^wro
    • 8321
    Zamieszczone przez mikkoranto
    I have an older maxidot in my car.
    This is your problem - the same got one guy who bought from me a newer one tacho.
    Is it possible to get to work Facelift model instrument cluster in my car?
    It depends of you current one - what is the MR of your car? Part number of tacho ?
    Apparently the immo is the problem?
    This question you should ask directly to spacewalker As far as I know there is no problem in installing the FL instruments into the older O2 version. The only thing is to make immo work.
      mikkoranto,
      regarding tach & immo please ask Spacewalker directly, via PW here:
      or better on vwortex here:
      As far I know, there is not possible to swap the tacho using VCDS only. It requires a little knowledge and more little expensive equipment, however it is possible.
      • mikkoranto
        • 3
        Here is autoscan instrument cluster:
        Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
        Part No SW: 1Z0 920 842 J HW: 1Z0 920 842 J
        Component: KOMBIINSTRUMENT VD1 1614
        Revision: V0003000 Serial number: SKX7Z0H532B07N
        Coding: 0007101
        Shop #: WSC 18769 000 1048576
        VCID: 3E78C31869E5F9E8127
        I'm trying to connect to tomorrow to Spacewalker if he could help in this case
        Thank You very much
          what i'm thinking is, You need to come to PL to do it, or purchase the necessary interface for tacho.
          • misiek^wro
            • 8321
            Czujniki szare ABS pod 2.0 na tył były podawane dla Passata?
            Jeśli tak, czy ktoś ma może taki numer dla Pazdziora 4motion ?
            • bohen
              • 1260
              • CCZA 2.0 TSI RS 200 KM
              misiek^wro, proszę
              - WHT 003857 A - lewy tył
              - WHT 003856 A - prawy tył
              • misiek^wro
                • 8321
                256 sztuka
                • spacewalker
                  • 942
                  po 220zł juz udzie wyrwac.
                  To samo chyba jest do Tiguana
                  • bohen
                    • 1260
                    Te czujniki montowane są też do Tiguana, G7, O3 i pewnie jeszcze parę aut się znajdzie.
                    • spacewalker
                      • 942
                      Misiek.... Tyle juz wsadziłes, co to 500zł na 2 czujniki przy całym wkładzie i nakładzie
                      • misiek^wro
                        • 8321
                        Tja....
                        [ Dodano: Czw 04 Lip, 13 17:38 ]
                        A te z koncowka B ?
                        • spacewalker
                          • 942
                          Ja bym nie kombinował, juz 2 sprzedałes bo nie pasowały. Tych z Touarega to tak łatwo juz nie sprzedaz
                          • misiek^wro
                            • 8321
                            spacewalker, ciagle ich nie sprzedałem, w tym problem
                            [ Dodano: Sro 10 Lip, 13 00:03 ]
                            [youtube]http://www.youtube.com/watch?v=yUKZ-YST5Ek&feature=youtu.be[/youtube]
                            Jeszcze bez czujników ABSu i z uwalonym G85 - nie wiem co się stało.
                            Może ktoś mi potw :
                            44 - 4 kodujemy z 0 na 2
                            03 - b18 bit 4 i 6
                            + kodowanie sterownika 3AA ?
                            [ Dodano: Czw 11 Lip, 13 21:18 ]
                            Dorwałem czujniki - po 18x sztuka
                            • kowaltom99
                              • 743
                              Zamieszczone przez misiek^wro
                              Może ktoś mi potw :
                              03 - b18 bit 4 i 6
                              44 kanał 4 adaptacja z 2 na 1
                              03 17,0 18,4 18,6
                              • Witek 703
                                • 109
                                Witam serdecznie
                                Mam Skodę z 2005 roku.W oryginale miałem zamontowany OPS z ośmioma czujnikami.Przy lakierowaniu zderzaków postanowiłem dołożyć jeszcze po dwa czujniki z przodu i z tyłu.Dodatkowe przednie czujniki mają numer 1T0 919 297 A,tylne 4H0 919 275.Wiem,że nie mogę liczyć na PLA w wersji 1,5 ani 2,0.Chciałbym mieć na Columbusie wskazania z czterech dodatkowych czujników.Czy wymiana modułu 1Z0 919 475 E na 3AA 919 475 A załatwi tą kwestię.Dodam,że dodatkowa instalacja od czujników jest już wpięta w złącza przy module.
                                PS.Co do PLA to mam pompę ABS o numerze 1K0 907 379 K.W auto skanie jest ona opisana tak:ESP FRONT MK 60 wersja SW 0104,kodowanie 0006786.
                                Pozdrawiam gorąco i czekam na odpowiedź.
                                Witek
                                • piotrek_gdy
                                  • 7723
                                  Witek 703, wymień pompę na taką która obsłuży PLA :wink:
                                  ja mam na zbyciu pompy AD, AC i BE
                                  • spacewalker
                                    • 942
                                    Ale w 2005 to nie było magla co PLA obsługuje, więc pompa to początek zabawy w zasadzie.
                                      • 11003
                                      i nie było zegarów obsługujących to
                                      • spacewalker
                                        • 942
                                        Zamieszczone przez krzynol
                                        czyli ... obaj wpadliśmy na ten sam plan, czyli jedna sztaba Pan Lipski, jedna Pan Siara .....
                                        • Witek 703
                                          • 109
                                          piotrek_gdy,krzynol,spacewalker dziękuję za odpowiedź w temacie.Bardziej chodziło mi o uzyskanie odczytu graficznego na Columbusie z dodatkowych czujników.Wracając do przekładni kierowniczej to jest dosyć ciekawa sprawa-w adaptacjach na kanale 4 mogę zmienić wartość z"zera na jeden"
                                          Marcinie- jeżeli moja maglownica nie zadziała,to o jakim numerze musiałbym szukać?
                                          Pozdrawiam gorąco.
                                          Witek
                                          • 1 6 D
                                            • 547
                                            Opis kanału adaptacji we wspoamaganiu.
                                            A004,0,Installation Park Steer Assist
                                            A004,5,Installation Park Steer Assist
                                            A004,6,0 = Park Steer Assist (PR-7X5/7X6) installed (< MY 2009 / PLA 1.0)
                                            A004,7,1 = Park Steer Assist (PR-7X5/7X6) installed (MY 2010 > / PLA 1.5/2.0)
                                            A004,8,2 = Park Steer Assist (PR-7X0/7X1/7X2) NOT installed
                                            http://chomikuj.pl/lusob/VCDS
                                            • piotrek_gdy
                                              • 7723
                                              Witek 703, tu masz kilka podpowiedzi
                                              • spacewalker
                                                • 942
                                                Ja miałem 144M i był błąd od PLA 2.0 w maglu , mimo ze podają ze działa, tak samo było na L, ale PLA działalo równolegle i prostopadle, jedynie był problem z wyjazdem z zatoczki
                                                Teraz mam J500_APA i błedu brak i wszystko bangla jak powinno.
                                                najlepiej aktywować i zobaczyć czy zadziała.
                                                Jak nie to możesz wymienić sam serwomotor, bo ja tak własnie zrobiełm.
                                                • Witek 703
                                                  • 109
                                                  Chłopaki serdeczne dzięki za podpowiedzi.Jak dorwę trochę czasu to poczytam i spróbuję coś zadziałać w tym temacie.
                                                  Jeszcze raz dziękuję !
                                                  Witek
                                                  • kowaltom99
                                                    • 743
                                                    Na Aliexpress pojawił się dedykowany przycisk do Park Assist dla OII.
                                                    Wychodzi około 100PLN z przesyłką
                                                    Wczoraj zamówiłem :-)
                                                    Link:
                                                    aliexpress
